Digi uvodi hibridne (DVB-S2/T2) prijemnike
Quote:Digi reveals set-top plans
Published: 11.28 UTC, March 1, 2011 by Chris Dziadul
BELGRADE BUSINESS BREAKFAST: The Romanian multimedia company RCS&RDS, which has a presence in the DTH and cable markets of several Central and East European markets through its Digi operations, has revealed its plans for a next generation set-top box.
The modular receiver, which is currently being developed with the assistance of current manufacturers Hyundai and Humax, could play a key role in Serbia’s transition to digital broadcasting, due to be completed on April 4 next year.
[Image: marcel-popa-belgrade.jpg]
According Marcel Popa, the general manager of Digi Sat, the Serbian branch of RCS&RDS, the box will be a hybrid allowing for the reception of both the Digi DTH service and terrestrial DTT channels, the latter free of charge. This is particularly important in the Serbian market where the public channels are absent from the DTH platform and Popa called for some sort of ‘Must Carry’ to be introduced. Popa was speaking at the Belgrade Business Breakfast, organised by Broadband TV News, in association with Telenor Satellite Broadcasting.
It will employ DVB-S2 and MPEG-4 compression and allow for the gradual introduction of additional services as HD, PVR, VOD and PPV at a later date. The use of DVB-S2 also allows a migration path that would ultimately safe the platform valuable bandwidth on the Intelsat 10-02 satellite (one degree West).
The box, which is described as a “multi system receiver”, will also be deployed in other RCS&RDS markets.
A decision as to what middleware it will use will be made centrally in Bucharest Serbia’s transition to digital broadcasting could also be helped by the incumbent telco Telekom Srbija, which already offers the services of a contribution TV network.
http://www.broadbandtvnews.com/2011/03/0...top-plans/
...valjda je za ovu temu Thumb up
Konačno da se neko zainteresovao za DVB-T2 prijemnike. Verovatno će digitalna zemaljska televizija biti pod brandom "Digi TV" pošto prijemnik podržava i Digi i digitalnu zemaljsku TV. Nažalost ima takvih zabiti kao što je selo Mokra kod Bele Palanke gde je prijem sa glavnih predajnika veoma loš, sa lokalnog repetitora (Veliko Kurilo iznad Bele Palanke u ovom slučaju) se emituje samo RTS a jedina mogućnost prijema ostalih kanala je Total ili Digi. Digitalizacija će spasiti takva sela od tog problema i čovek u selu Mokra će imati skoro isto što i npr. u Pirotu. A ovo nema veze sa 3DTV pa neka se to premesti u opštu temu ili u temu o prijemnicima.
(01. Mar 2011, 15:48)BoshkoIgich Wrote: Verovatno će digitalna zemaljska televizija biti pod brandom "Digi TV"
Misliš, verovatno će Digi pokušati da proda priču da se zemaljski kanali emituju pod njegovim okriljem?
Možda će Digi TV izaći i na zemaljsku mrežu i promovisati uslugu "Digi TV preko antene" ili slično i ubaciti nekoliko kodiranih kanala.
Vrlo verovatno, otprilike kao i to da će digitalna zemaljska biti ukinuta za par godina kao nepotrebna jer će svi imati IPTV.
Digi ne može da uđe u zemaljsku sve dok se ne raspiše tender za operatere drugih multipleksa koji neće (obavezno) biti pod okriljem Emisione tehnike i veza, a to će se desiti ko zna kada.
Uz to, ne znam šta će u takvom slučaju hibridni DVB-S2/T2 prijemnik.
